64bit version of Firefox soon?
  • 2 replies
  • 16 have this problem
  • 2 views
  • Last reply by John99
I sometimes have a lot of tabs open in a window and Firefox doesn't seem to like that. Seems like a 64bit version would fix that issue, assuming memory limitations. I like Firefox and would like to continue using it, but would like a 64bit version.
When you say 64-bit Firefox you mean for Windows as Mac OSX (combined 32/64) and Linux has had 64-bit for Release ever since Fx 4.0. For Mac and Linux it was both easier and needed.
For Win64 the earliest there may be is Firefox 37.0 in a first phase if all goes well in best case scenario. https://wiki.mozilla.org/Firefox/win64
Since Win32 works fine and Win64 is not needed in order to run Firefox on 64-bit Windows it has not been a priority to get through the different hurdles in having Win64 Firefox for Release until again more recently.
Modified by James (On Leave)
That is something that has not had much work on it until recently.
IIRC work is being stepped up but I am not sure any Release is imminent. I found this
This suggests it could be as early as Firefox 37
If you ask briefly and politely on one of the fora | mailinglists | groups
You may get an answer or at least be told where the correct place is to ask
